My Oil Light Is Flickering very dimly below a 1000 rpm.
First Thougt faulty pressure switch fitted new switch still the same.
Even with wire (brown/white) disconected at plug near alternator still the same.
Before i start opening up the loom to see if it is chafed through any Ideas Chaps.
2.5 TD 4wd Auto freetop plenty of oil in and no Knocking so pressure is fine ang light goes off when revved above 1000 rpm
Bongoliers
As The Switch Had Been Replaced , And The Fault Was Still There With It Disconnected It Had To Be a Wiring Fault.
The Brown With With A White Tracer Cable Coming From The Pressure Switch Was Cut At The Switch End And Where It Goes In To The Smaller Plug Of The 2 That Plug Into The Dash Pod And a New Piece Of Cable Spliced In.FAULT CURED.... NEW CABLE ROUTED CORRECTLY AND SECURED. It Takes Far Less Time To Do This Tham Try To Trace Whwre It Was Going To earth..
IF IN ANY DOUBT CHECK OIL PRESSURE FIRST.
Thanks For Your Comments
