roof problems.
roof problems.
i am having problems lifting my roof.i haven't used the roof space for around 5 months and now it won't lift at all..could it be the fuse? if so which fuse is the roof one? thanks
Re: roof problems.
Before investigating further, have you checked the obvious? The handbrake must be on before the roof will go up.
- mister munkey
Re: roof problems.
I sometimes suffer this. Mine seems to have a bit of an erratic switch under the handbrake. Dropping it & yanking it up again eventually makes it work.
Re: roof problems.
yeah i've tried handbrake stuff and without the engine running to hear if the motors are running!
Re: roof problems.
30 amp fuse, second row down, fourth from left. But I'm with Mistermunkey, I reckon it will be the switch at rear of handbrake.
Re: roof problems.
ok guys thanks,i'll go out and give things another go and post how i get on in a mo.cheers
Re: roof problems.
if it's the hand brake the light on the dash wont come on
