Hi there,
Does anyone know where the low pressure valve on the air con is located. I have the kit to test but can't see the valve, high pressure one is obvious though.
Andy
Air Con Low Pressure Valve Location
- brorabongo
Re: Air Con Low Pressure Valve Location
I think...but don't quote me on it. The valve is accessed when you remove the cowling/ducting for the blower fan? (or there abouts)
I've a feeling thats right. Either that or its visible next to it without even moving the cowling. I'm sure I spotted a likely suspect when I had the bonnet up not long ago, but can'r temember if I had the cowling off.brorabongo wrote:I think...but don't quote me on it. The valve is accessed when you remove the cowling/ducting for the blower fan? (or there abouts)
Anyone else out there know?
- helen&tony
Yup!....I just spotted it behind the radiator while checking my rad.
Great thanks for the info. On mine the high pressure valve is by the radiator and I couldn't see the low pressure one. I'll take another look later on.
Andy
Andy
