Fuel Pump Leak - a bit different this time
Slybacon
Post by Slybacon » Mon Apr 14, 2008 9:40 pm
I've been tracing a leak from my fuel pump and am sure that it is coming from the rear of the unit where the 4 fuel lines leave the pump. You can clearly see the drips of diesel in the picture below. I think the drip maybe coming from the plug at the end of the pump as there is an o-ring behind it.
Has anyone had any experience of removing this plug and replacing the o-ring? If so, can it be done in situe and are there any pitfalls I should be aware of? I've read the excellent posting by Dandywarhol on replacing the other 2 o-rings, but I'm pretty sure the leak is coming from the plug (when I run a finger over the area near the other 0-rings I don't get any diesel).
Any advice/comment would be appreciated.
Andrew.
Ralph
Re: Fuel Pump Leak - a bit different this time
Post by Ralph » Mon Apr 14, 2008 9:57 pm
Not sure but it looks like it may have a soft aluminium washer under it.
dandywarhol
Post by dandywarhol » Mon Apr 14, 2008 10:16 pm
Should be ok to open that - it's where the DTI gauge is inserted for timing it.
Slybacon
Post by Slybacon » Tue Apr 15, 2008 2:54 pm
Thanks for the advice folks.
Right, now I'm 95% sure the leak is coming from the "plug" and I've been trying to get the thing off. 2 problems, 1: I can't easily get a socket in to remove it, 2: I'm not sure if the usual hex socket will fit - because of the unusual shape.
Does anyone know if, 'cause I lack a bit of experience in this area, whether a hex socket should undo this or do I need a special socket?
At the moment, it looks like the only way in is to remove 1 or two of the fuel lines.
oglivy0
Post by oglivy0 » Wed Apr 16, 2008 9:49 pm
Please refer to my answer to your last question. :?
