Cleaning the injectors
Post by Simon Jones » Thu Apr 10, 2008 11:33 pm
Anyone got any advise on whether its worth / wise to clean the injectors? If so, how? They're quite sooty, but the mechanic whose helping me with my overheating problems says they're quite a precise piece of engineering with very tight tolerances. Suggestions either way much appreciated.
Bongoplod
Re: Cleaning the injectors
Post by Bongoplod » Thu Apr 10, 2008 11:43 pm
Every 6/7 tankfulls,i buy the proprietory injector cleaner ,available from most garages
£7 ,does two tankfulls and is supposed to increase MPG/performance...not sure if it does,but i get it anyway.
Brian
dandywarhol
Post by dandywarhol » Thu Apr 10, 2008 11:47 pm
Might be worth giving them to a diesel injection specialist or local college to spray test for performance.
Post by bigdaddycain » Fri Apr 11, 2008 7:07 pm
Your mechanic is quite correct simon,the injectors are very finely tuned pieces of kit,the spray pattern determines how well,or not your engine will run...
This link may be of benefit to you simon....
http://www.injectorcleaning.co.uk/post.htm
Post by Simon Jones » Fri Apr 11, 2008 10:07 pm
Cheers BDC. I'll have a read - it looks like they only do petrol injectors
