Springs on Rear Pads
Nibs
Post by Nibs » Thu Apr 10, 2008 8:21 pm
:D :) 8) :lol: Hi all, anyone know where I can obtain the springs for the rear brake pads? tired of hearing the clonk from the rear every time I brake. Summer is coming and I like to drive with the windows down.
Cheers Nibs
Re: Springs on Rear Pads
Post by francophile1947 » Thu Apr 10, 2008 8:27 pm
Are there springs on the pads? :?
I've never done the Bongo's, but have never seen springs on any other car.
robdrinky
Post by robdrinky » Thu Apr 10, 2008 8:41 pm
not sure which is your model but looking at lushprojects some models appear to have a spring/shim arrangement. 8)
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Nibs
Post by Nibs » Thu Apr 10, 2008 8:48 pm
:lol: 8) :) :D Yes robdrinky you are correct there is a spring/shim arrangement, never had the springs and dont come with new pads, which are quiet when you first put them in, but when a little worn back comes the CLONK.
Cheers Nibs
Ralph
Post by Ralph » Thu Apr 10, 2008 9:16 pm
Think I have seen some in Halfords may be call anti rattle shims
but don't know if they do a set that will fit the Bongo.
robdrinky
Post by robdrinky » Thu Apr 10, 2008 9:19 pm
perhaps someone thats breaking one may have what you need.
a couple are on ebay and also bellhill to name a few. 8)
carlioll
Post by carlioll » Thu Apr 10, 2008 10:20 pm
Havent done rear pads but my new front ones came with new spring clips which retain the inside pads in their caliper.
Nibs
Post by Nibs » Fri Apr 11, 2008 6:00 pm
:D 8) :lol: Thanks for replies, can I ask you carlioll where you purchased your front pads? You must have got the two shims shown in the workshop manual, I would be intrested as to wether the springs would come with the rears.
Cheers Nibs
carlioll
Post by carlioll » Fri Apr 11, 2008 10:44 pm
Not sure that we are talking about the same thing here -I thought you were looking for the spring clips which hold in the pads on the piston side of the caliper but you now mention the anti squeel shims -two totally different items. My front pads came from AVA Leisure and included new spring clips but not anti squeel shims. From memory, the spring clips are about an inch long and the anti squeel shims are the size of the disk pads. There was nowt wrong with my old clips and if this is what you are looking for then I am pretty certain that I have these somewhere.
Nibs
Post by Nibs » Sat Apr 12, 2008 8:44 am
8) :lol: :) :) Hi carlioll, diagram in the workshop manual shows outer shim/inner shim and a spring which looks like it pushes the pads towards the piston when brakes are off, this means that there is no take up when brakes are applied. Pretty sure that is the CLONK I hear when braking.
Cheers Nibs
dandywarhol
Post by dandywarhol » Sat Apr 12, 2008 9:47 am
Niibs
Do you mean part 26-233?
They don't come with the new pads, they're part of a shim/spring kit. But I don't think that will cause your clunk.
Is the clunk whenever you brake after changing direction? It could be the handbrake shoes sticking slightly.
Nibs
Post by Nibs » Sat Apr 12, 2008 11:06 am
:lol: 8) :) :D Hep, thats the part, and no its not after changing direction, its everytime I brake. Other members have had this too as it has been mentioned in the past, I just want to solve it!
Cheers Nibs
