ATF change?
manners
ATF change?
Post by manners » Mon Apr 07, 2008 5:55 pm
Got this off the Q&A at manufactures of the auto boxes web site Jatco LTD.
Q. How often should the oil be changed in automatic transmissions?
Our products basically do not require oil changes.
There are CVTs, however, that signal the need for an oil change and you should therefore check the handling manual of your vehicle for details.
dandywarhol
Re: ATF change?
Post by dandywarhol » Mon Apr 07, 2008 6:57 pm
Mazda recommend 25,000 miles for the Bongo - I think I'd go with that info - save a grand for other things in life :)
