Tyre size
squeaky
Tyre size
Post by squeaky » Sun Apr 06, 2008 9:33 pm
I know this has probably been asked before, but what is the best tyre size/price for 17" wheels :?:
I've checked the tyre size calculator and several sizes would be ok
205/55 or 215/55 or 215/50 or 225/50 or 225/55 but what do other have fitted :?:
Re: Tyre size
Post by francophile1947 » Sun Apr 06, 2008 9:39 pm
205/55 is the nearest to the original tyres, but I'd probably go for 225/55 as the speedos invariably read fast.
madmile
Re: Tyre size
Post by madmile » Sun Apr 06, 2008 10:22 pm
I regularly use 17's with 215/55/17 Accellera tyres which are 98 XL and around £60 each. No problems so far.
bonog
Re: Tyre size
Post by bonog » Mon Apr 07, 2008 7:14 pm
The issue that you have is finding a "car" style tyre with the required weight rating needed for the Bongo. At 205 you will probably struggle to find any tyres greater than the minimum weight rating 96 on 17"ers on you profile. At 225 you will probably find plenty greater than 96 but at a higher prices and higher rolling resistance! Why not compromise on 215 (as I did). I chose Sumo Firenza ST-05 215/55R17 (98load) at about £60 each which seem absolutely fine or if you can afford it Pirelli P7 XL 215/55 R17 (98 Load) at about £120 each.
http://i109.piczo.com/view/2/e/u/m/h/d/ ... 1801_2.jpg
You wanna buy DVD?
