abs fault
robdrinky
abs fault
Post by robdrinky » Thu Apr 03, 2008 9:55 pm
by way of an update to our abs fault light being on intermittently(previous post in jan).
the fault light has been on consistently for the last couple of weeks and the mot is looming.
i decided to do some fault finding again-turns out now that the drivers side front sensor has no continuity and gives a very low output voltage(compared to the others) when the wheel is spun. :shock:
at least thats something positive-just got to source and fit a new one then hopefully that will be job done. :)
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Veg_Ian
Re: abs fault
Post by Veg_Ian » Fri Apr 04, 2008 7:31 am
Fixing ABS can be an expensive job. At least a sensor should be a cheaper proposition than the pump. A dealer may be your best proposition for one or alternatively you could try the club's Partfinder service.
Re: abs fault
Post by bigdaddycain » Fri Apr 04, 2008 9:35 am
All we've got to do now is work out which other (more generally available mazda) used the same sensor.... erm..... :?
lochan2
Re: abs fault
Post by lochan2 » Fri Apr 04, 2008 11:15 am
Watching this thread with interest......my ABS light has been on constantly now for months, and my MOT is looming too. None of the garages up here seem to have a clue because theres no 'OBD' style diagnostic port on the Bongo to tell them whats wrong :cry:
regards lochan2
robdrinky
Re: abs fault
Post by robdrinky » Thu Apr 17, 2008 5:02 pm
recieved a new abs sensor in the post today.fitted it,turned on the ignition and the 4wd abs light went out straight away-result =D> .
daveblueozzie
Re: abs fault
Post by daveblueozzie » Thu Apr 17, 2008 5:11 pm
robdrinky ,if you could post a part number and where you bought it from, would be useful to other bongoers.
glad you sorted it out ,quite annoying the light staying on for no apparent reason
Lost without my Bongo.
robdrinky
Re: abs fault
Post by robdrinky » Thu Apr 17, 2008 5:29 pm
Apart from the part number on lushprojects i have no other numbers.
I got the part from automotive japanese spares in coventry,mainly because they could get one to me in a couple of days(mot looming).
Also ians partfinder service and bellhill could supply. 8)
westonwarrior
Re: abs fault
Post by westonwarrior » Thu Apr 17, 2008 5:33 pm
Great news, how much????
Pete & Sue
Re: abs fault
Post by Pete & Sue » Fri Jun 06, 2008 8:34 pm
Yes! how much!
Pete & Sue
Turned out nice again!
maxheadroom
Re: abs fault
Post by maxheadroom » Fri Jun 06, 2008 9:23 pm
lochan2 wrote:Watching this thread with interest......my ABS light has been on constantly now for months, and my MOT is looming too. None of the garages up here seem to have a clue because theres no 'OBD' style diagnostic port on the Bongo to tell them whats wrong :cry:
regards lochan2
I thought there was down in the passenger foot well :o
Keep the Faith
robdrinky
Re: abs fault
Post by robdrinky » Fri Jun 06, 2008 9:29 pm
on my bongo the port i think you are refering do doesnt do the abs-would make things a lot easier if it did. 8)
Pete & Sue
Re: abs fault
Post by Pete & Sue » Fri Jun 06, 2008 10:08 pm
Yes, but .... How much was it.
Pete & Sue
robdrinky
Re: abs fault
Post by robdrinky » Sat Jun 07, 2008 10:18 am
one abs sensor cost me £112 inc p&p.
Pete & Sue
Re: abs fault
Post by Pete & Sue » Sat Jun 07, 2008 12:04 pm
Thanks very much for the info.
Pete & Sue
Pete & Sue
Re: abs fault
Post by Pete & Sue » Mon Jun 09, 2008 11:00 am
Having same trouble with my ABS light, staying on all the time. Up in Claughton at the moment. Where are the rear sensors situated in relation to rear wheels and how do I check them (the sensors) with a meter, which I haven't got? Being a bit of a numpty I need 'Janet and John' instructions!
In the meantime I will contact 'Wheelquick' again and ask them if they can check them out.
Pete & Sue
