tay
Post
by tay » Sat Mar 29, 2008 2:16 pm
just brought a split charge relay kit which requires me to tap into the D+
wire of the alternator.having read posts about this causing problems with
battery light staying on i am a bit wary to do this. Is there another way to
pick up a D+ wire without using the alternator or have i got to buy another kit.please dont get to technical with your answers as i am a simpleton! cheers.
Veg_Ian
Post
by Veg_Ian » Sat Mar 29, 2008 2:41 pm
Yes that's right, if you splice into the wire from the alternator you will find your dash lights glowing as if the alternator is duff. You can get around this by picking up an ignition controlled source from elsewhere such as the radio. That's not ideal but will work. Better still to fit a voltage sensing relay between your split charge relay and battery live.
tay
Post
by tay » Sat Mar 29, 2008 3:28 pm
thanks for that,any ideas where i can get one and do i put it in line with the split charge relay
Post
by missfixit70 » Sat Mar 29, 2008 5:00 pm
flippa
Post
by flippa » Sat Mar 29, 2008 5:39 pm
tay
Post
by tay » Sat Mar 29, 2008 6:04 pm
thanks dont know what i'd do without you all. the volt sensing thingy from
willinton is just what i need. I think i can incorporate it into the kit ive just
brought and only for a few dollars more! cheers again guys
Glenda
Post
by Glenda » Sat Mar 29, 2008 6:17 pm
I'm getting the split charge relay from Willintons and the leisure battery tray. Thanks for info on this. Do I need or would it be any use to have volt sensing thingy? Or is the split charge relay kit sufficient?
Secondly any advice on good leisure battery to buy? I'm in Brighton. Thanks.
tay
Post
by tay » Sat Mar 29, 2008 6:30 pm
i think the kit willinton sells has an intelligent relay which already has the volt sensing thingy inbuilt,so you should be ok.
Glenda
Post
by Glenda » Sat Mar 29, 2008 7:48 pm
Thanks for that, Tay.
