hi all,
i did an oil and filter change on my petrol v6.filled the oil to the level i thought(7 litres with oil filter)but i have developed a slight oil leak,from an as yet unidentified source.it`s not apparentlt from the oil filter,or the previously believed-to-be-leaking-but apparently-not rocker cover gasket.
i have since been told by another member that the oil capacity on the v6 is only 4.5 litres after all.is this true?if so,would the excess oil be making its way out of an oil breather pipe somewhere and leaking out that way?
thankyou
jamie
oil breather on petrol v6?overfilled oil & now slight le
It is 4 1/2ltre, i'tll do as much damage as having to little oil, not good
I overfilled mine first time i did it, not to 7ltre tho
drained excess off before i started it. Must admit it is a pain in the arse to keep runnin round other side of van to check dip when filling up first time
oil overfill
hi Jamie, judging by the dipstick i would say you have more than enough of the slippy stuff.Running the engine with that much oil in could create a back pressure and blow an oil seal.Drain it off Best of luck Lionel
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
I bet it smoked like a good un with that much of an overfill eh Hoggman?hogggman wrote:hi,
yes,there is a dipstick-me!!if you imagine the upper and lower marks on the dipstick,it is over the higher mark by the same distance as between the lower and higher marks,if that makes sense?
thanks
jamie
