Pela oil change.
mikelamb
Pela oil change.
Used my new pela pump yesterday, but it took the best part of 4 hours to suck out about 5 litres of oil! Followed the suggested procedure by running the engine for a while to heat the oil, then stuck the pipe down the dipstick hole until a definite contact was made with the bottom of the sump, punped the pela about 15 times and sure enought the oil started to flow, but should it be such a slow process? I had to give up in the end as darkness was falling! Any advice will be much appreciated, Mike.
- haydn callow
mikelamb
mikelamb
Just come back in after trying to suck the oil out of the 5 litre can with my pela, in the time that I was there (probably going on for an hour) I only managed to suck up about 3/4 of a litre. It seems to be creating a good vacuum because when I pull the pipe out of the oil you can hear it gurggling. Perhaps the pump is faulty, I cant think of anything else to try as its such a simple procedure!
Mike.
Mike.
Have PM'd you Mike - sorry, did that before I read this. To summarise, there has to be something wrong - Pelas empty the sump in 20 mins or so. Maybe sludge in the sump - I've not heard of it before though, but you will be able to tell by looking at the end of the probe. Other thought - has someone put 100W oil in it -
mikelamb
Pela pump
Cheers Nibs
Veg_Ian
mikelamb
Thanks for your replys, I decided this morning to give the pump another go, firstly using water, (like veg_ian suggests it should be able to do that!) it drained this with no problem (about 3 litres in 5 minutes roughly, perhaps even less time!) So then decided to give the oil from the bongo in the 5 litre can a go, again this seemed slow, decided then to try some new oil I had in the shed (15/40) again seemed slow. So then decided to take a spin back to the marine shop for some advice, the owner is a really nice guy and was happy to refund me, but we tested the pump and all seems fine with it, it creates a really good vacuum which is basically all it needs to do. We came to the conclusion that it must be down to the viscosity of the oil and that perhaps I needed to get the oil warmer than I did before starting the extraction. I'm going to give it another go but this time I will get the engine up to running temp before starting. Any comments are greatly appreiciated,
Mike.
Mike.
dp bradford
I used to have a small hand operated pump that would take AGES to empty a few litres, MUCH worse if the oil was cold or semi-cold.
Last time I changed my oil, it was immediately after the engine was at full operating temperature. It took less than 10 minutes to extract 6 litres
Warm your oil up properly!
Dave
Dave
Perhaps it may have been better to drain the oil half an hour after shutting the engine down after a run mike? You'd be suprised at how "pi55y" the oil is when still hot/warm after a run, as opposed to waiting for the oil to heat up,from cold, on tickover...
I reckon the hot 10/40 semi synth isn't dissimilar in viscosity than straight water?
bongomaan
