Temp Gauge being erractic!
Bigblackbeastiebobbongo
Post by Bigblackbeastiebobbongo » Sat Mar 22, 2008 11:38 am
Hey, I'm so paranoid about high temps after reading stuff on here, so until we get the mason alarm and the haydn alarm fitted I'll be asking a few questions to make sure everything is OK!
I was driving along to work yesterday, 35 miles - averaging 50-60pmh and I noticed the temp gauge started flickering up and down when on the faster stretches of road, it would sit at the cold and then jump up and down, but when driving on the normal stretches of road it was fine. Any ideas?
Post by haydn callow » Sat Mar 22, 2008 11:48 am
Sounds like a fault in the temp sensor...wire..or gauge..
PM on the way
corblimey
Post by corblimey » Sat Mar 22, 2008 12:51 pm
If I were you it's not your temp gauge I'd be worried about it's the avatar police.
That's a whooper you've got there Bigblackbeastiebobbongo!
maxheadroom
Post by maxheadroom » Sat Mar 22, 2008 12:52 pm
Bigblackbeastiebobbongo,
don't want to panic you but I had similar problem, it turn out to be the water pump. Easy job to fix and got it from the club shop. See the threads below for reassurance.
http://www.igmaynard.co.uk/bongo/forum/ ... highlight=
Keep the Faith
waycar8
Post by waycar8 » Sat Mar 22, 2008 1:32 pm
sounds like temp sender to me,i had the same problem, but i replaced both temp sender and thermostat, which solved the problem. better safe than sorry
helen&tony
temp gauge
Post by helen&tony » Sat Mar 22, 2008 1:45 pm
Having checked everything as suggested, there is another possibility, and that is the voltage stabiliser up behind the instruments somewhere....I had a similar problem some years ago on another car...the temp gauge was highly erratic.
Post by Bigblackbeastiebobbongo » Sat Mar 22, 2008 10:22 pm
Thanks for your help! not sure what is up with it. We were out today on a 100 mile round trip and it was fine! *shrugs* Guess I will have to persue the temp sender and water pump ideas.
Post by Bigblackbeastiebobbongo » Sat Mar 22, 2008 10:54 pm
lol corblimey I spent ages trying to figure out how to resize it, this newfangled photobucket business isn't as straight forward as it seems! Maybe its my age (36 and three quarters) :shock:
