Stuck in Low gears when first starting up
Bigblackbeastiebobbongo
Post by Bigblackbeastiebobbongo » Fri Mar 21, 2008 9:50 pm
I have just read the thread on Throttle position Sensor and I am wondering if we have the same problem. Ours doesnt seem as bad as that though. When first starting up, it seems to be stuck in 3rd for a while, maybe for the first 2 -3 miles and then it changes up ok. It is ok if you are going at less than 40 but if you try to get up to that and over then it wont shift up. I spoke to the lass we bought it off and she said it had done it since they bought it (3 years ago) but had never caused any problems. It seems to be ok when the engine is warm, which is why I am not sure if its the TPS or not. Can you guys shed any light on this? your advice would be much appreciated. Cheers :D
Post by francophile1947 » Fri Mar 21, 2008 9:56 pm
What you describe is perfectly normal - transmission doesn't lock up until ATF is warm enough and you are doing 40ish.
dandywarhol
Post by dandywarhol » Fri Mar 21, 2008 9:59 pm
It won't take 4th until there's some warmth in the 'box and engine and will finally take lockup when the needle moves - around the same time as the glowplugs knock off.
I live in the city and although I knew about the lockup temperature delay, I didn't know about 3rd until it was mentioned on here and I drove away from an overnight stay in the styx. :oops:
Post by Bigblackbeastiebobbongo » Fri Mar 21, 2008 10:18 pm
HEY GUYS!!! Thanks so much! Thats is a RELIEF! You are such a helpful bunch of people and so friendly! It is just wonderful the way you help other bongo owners. Hopefully one day when we are Pro Bongoians we will be able to return the favours! :D :D :D
