Sliding door closure
Posted: Sat Mar 15, 2008 5:19 pm
by Ame
Sorry in advance if this is a repeated subject.
My sliding door quiet closure system doesnt work. The previous owner had a Viper Alarm and central locking system fitted and Im just wondering if this is the likely cause of it not working.
Anyone got any thoughts or experience of the same thing?
Ames
Posted: Sat Mar 15, 2008 5:42 pm
by missfixit70
Try cleaning the brass plunger contacts with some fine emery cloth & make sure the ones that move are moving freely, squirt of wd40? do the runners top & bottom while you're at it.
Is the door itself opening & closing ok, ie not getting stuck in the locked position?
Posted: Sat Mar 15, 2008 5:50 pm
by David Edwards
Also check fuse under the dash and the wires between the drivers door and pillar.
Posted: Sun Mar 16, 2008 2:53 pm
by Ame
Thanks for replies, the door and lock works fine its just the soft/quiet closure system that's not working. Gave it all a clean which made no difference.
Will try to locate wires and have a jiggle!
Posted: Sun Mar 16, 2008 3:25 pm
by westonwarrior
Daft question time
Has it ever worked?
Some were made without the soft closing , if you have 5 contacts 3 are sprung then you have the electric closing doors if you just have 2 then sorry to say you dont.
fuses are my guess
Posted: Sun Mar 16, 2008 4:40 pm
by Ame
AAhhh, that'll be it- I only have the two pins so guess it has never worked. Do you know what the little switch in the door is for then? (I assumed it was something to do with the closure system).
Posted: Sun Mar 16, 2008 4:48 pm
by Steve L
Small switch on the edge of door itself is for the child lock to prevent it being opened from the inside.
Posted: Sun Mar 16, 2008 4:49 pm
by Ame
Great, thanks for all the help.
