rear brakes...
littlewoods
rear brakes...
Post by littlewoods » Sat Mar 15, 2008 11:00 am
any advice would be welcome my bongo has just failed the mot....it failed on nearside rear parking brake recording little effort... i would presume that new rear brake shoes are required ? question is
1. are the parts they easy to get hold off
2. is their anything else required for the job
3. is it a straight forward job.
its an aug 97
thanks
mister munkey
Post by mister munkey » Sat Mar 15, 2008 11:48 am
I'm sure I'll be corrected if wrong but its pretty near imposible to wear the handbrake shoes down, unless they've been sticking on for a couple of thousand miles. Ideally the handbrake is only pulled on when stationary & is let off before you pull away so no friction involved.
It could be just a case of adjustment. . . . .
:-k
Pete & Sue
Post by Pete & Sue » Sat Mar 15, 2008 11:50 am
See Factsheets - Brakepads. Very helpful
Pete & Sue
Turned out nice again!
Post by francophile1947 » Sat Mar 15, 2008 12:24 pm
We used to get this a lot when I worked at a motor dealer. It's almost certain that the previous owner hardly used the handbrake and the cable/mechanism is stuck. Strip it down and release/lubricate the moving parts and it'll probably be OK.
littlewoods
Post by littlewoods » Sun Mar 16, 2008 10:22 am
it seems like a pin has snaped on what i presume is the fitting fit of the break shoes.
thanks all for advice
cheers
