Bleeding the coolant
Nobbybongo
Post by Nobbybongo » Fri Mar 07, 2008 3:37 pm
Read the coolant fact sheet, just one quick question, is the bleed hose the pipe towards the front of the head near the top under the passenger seat which is a pipe just blanked off. And is this the only bleed point on the coolant system?
Harry
Post by Harry » Fri Mar 07, 2008 3:42 pm
Yep...should be a long small bore rubber pipe clipped around the bay and ending up near the door. Just unclip it.
When finished make sure it won't chafe on the alternator.
H 8)
http://watcherswildlife.co.uk
