Heater control bulbs
nigelginny
Post by nigelginny » Sat Mar 01, 2008 1:27 pm
My beast has the slide type heater controls and one of the bubs has blown, anyone know where i can get a replacement? ive seen a few threads on here but they seem to be for bongos with the climate control.
helen&tony
heater bulbs
Post by helen&tony » Sat Mar 01, 2008 1:35 pm
Halfords...12v 1.2W part number 286 (halford's own)
nigelginny
Post by nigelginny » Sat Mar 01, 2008 1:41 pm
Thankyou, looks like im off to halfords. :D
panman
Post by panman » Sat Mar 01, 2008 2:27 pm
How did you get the heater control unit out? undo the three metal slide control rods and use ford radio keys? Mine seems to be caught on something behind dash , it releases but comes out a cm then stops..any ideas Cheers
helen&tony
heater bulbs
Post by helen&tony » Sat Mar 01, 2008 2:49 pm
To remove the heater controls (Manual aircon), look at the heater in the footwell, and you will see a cable with a round clip at the end on the side of the heater box...relese the cable . Do this each side, and there is enough slack to pull the unit out sufficiently to change the bulbs. The clips at the side must be released with a U-shaped radio key.
nigelginny
Post by nigelginny » Sat Mar 01, 2008 6:27 pm
Hi helen, purchased bulbs, perfect, thanks again for your help.
Rhod
Post by Rhod » Mon Mar 03, 2008 7:43 pm
No need to undo the rods - Helen has it right, though I had to remove the fresh/recycled air flap control cable as well.
Rhod
