Moving rear heater + fan controls
Chris&Gem
Post by Chris&Gem » Thu Feb 28, 2008 10:45 pm
Having an older bongo without climate controls, is it possable to move the manual controls from the middle to the rear , has anybody tried it.
If you have how did you do it. Had a look tonight, dosent look an easy job :?
daveblueozzie
Post by daveblueozzie » Thu Feb 28, 2008 10:55 pm
don't think it can be done ,they have rods to control the aircon. the newer climate controls can be moved with a bit of rewiring.
Lost without my Bongo.
madmile
Post by madmile » Thu Feb 28, 2008 11:20 pm
I am assuming you mean moving the controls (not the heater) due to the position of a conversion?
It is possible to move the controls, but only within reach of the cables that operate the system. If you searched hard enough I am sure you could find similar cables that were longer - but I have never taken it that far.
If you do move them, try not to kink or bend the cables much as they get very difficult to operate. I usually try to locate them in the plinth of a unit if possible.
