what coolant to use
shell&andy
what coolant to use
Post by shell&andy » Sun Feb 24, 2008 10:28 am
Can anybody recommend what coolant to buy(heder tank)
Post by Bob » Sun Feb 24, 2008 11:06 am
I think any anti-freeze suitable for aluminium and cast iron engines, mixed 50%.
westonwarrior
Post by westonwarrior » Sun Feb 24, 2008 11:29 am
check what you have there are at least 2 diferent types which are diferent colours, match what you already have
Peg leg Pete
Post by Peg leg Pete » Sun Feb 24, 2008 11:44 pm
Rob is correct, are you topping up or replacing? if replacing I would flush the system first then replace and Bleed the system :wink:
Image Pete
shell&andy
what coolant
Post by shell&andy » Mon Feb 25, 2008 9:48 am
Peg leg Pete wrote:Rob is correct, are you topping up or replacing? if replacing I would flush the system first then replace and Bleed the system :wink:
topping up
