Sliding door won't open
As described in a recent posting, Bongo has refused to start due to drained battery. I have now topped up the battery and it will start. Only problem now is that the sliding door won't open. I assume that the electric function has locked somehow. Any ideas?
- westonwarrior
It won't open from outside or inside. I suspect there was insufficient power in the flat battery to close the contacts properly and now they are stuck perhaps. Does anyone know the solution?
- maxheadroom
- westonwarrior
This post discribes your symptoms and how it was fixed
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=12536
Tried disconnecting battery but no luck. Any other ideas?
Have tried to check fuse without success. The manual refers to a chart showing the fuses-this does not appear to exist and what info there is in the fuse box is in Japanese. If I do find the correct fuse, how do I extract it?
Do i assume then that the solution is to remove the door panel and poke around a bit?
- westonwarrior
Sliding Door will open!
I have fixed the door! Hurrah!!
It was nothing to do with electrical things. I simply manhandled the mechanism in the lower section of the door and it released whatever was stuck and gave the familiar whirring noise.
You can imagine my relief.
Thanks to everyone who tried to help.
- westonwarrior
