Post
by Veg_Ian » Mon Feb 18, 2008 9:02 am
Do you get a whine from the bearings when running? If not it could be the bottom balljoint and not the bearing. Get a bar under it and see if there's any play. Unfortunately the balljoint is pressed into the subframe so you have to replace the lot. Check out the fact sheet if you end up going down this route and try a Mazda dealer for replacement rather than Bongobits - apparently cheaper!
