well another head gasket bites the dust
As some of you may know I just replaced my radiator after it sprayed all over the windscreen. Took it for a test drive today and I was leaving great clouds of white smoke.
Got to the garage and he reckons the head gasket. He has quoted £400. Is this good?
What else could be wrong? Whats the worse case scenario?
cheers
boyzie
cheers
boyzie
- haydn callow
Big Rich
Hi Boyzie . Whats the worse case scenario? you ask ? the head is shot !
I have had 2 heads fitted in 8 months ! one by hillside under warranty and the last one i did myself as its out of warranty now... very easy to do, and quite good access. BOTH down to water leaks, on last head fitted i fitted the temp monitoring sys from Auzzie land ... but recomend you fit the Haydn system on when you have sorted it, Today i have just completed fitting a full silicone hose setup and also found the the hoses to the gearbox leaking so i siliconed them as well, its took me almost all day ! must be getting old ? I have one good hose left ... its the one from the fuel pump side down to steel hose, its only been on 2 weeks and is like new ...its the hose that usually swells bad on the first bend...ps its a genuine mazda hose.....its free on first come basis .......anyway many thanks and good luck Rich
pps can i just say how good / fit the silicone hose set is, well worth every penny.
flippa
Big Rich
Hi flippa i first came across silicone hoses around 24 years ago when i worked as a bus fitter they were a wrapped type ..looked like bandages with silicone on ? very thick walls .....but the set off you were very plyable easy to fit and VERY good value for money i used proper jublee clips and they went on a treat ..just wondered flippa if you are thinking of doing any more hoses for the bongo ? can i just say my Freda has done 70.000 K and all hoses were hard and brittle so anyone reading this
CHECK YOUR HOSES any doubt get them changed dont risk your cyl head thanks Big Rich
flippa
