HELP. WHERE DOES THE OIL GO IN!
Kazanne
Post by Kazanne » Fri Feb 15, 2008 5:55 pm
please help a new bongolier i tried to top up oil I have a 2.5 petrol auto friendee 4D SG5W found the dipstick ok but where doe the oil go in as my engine dont look like the one on the fact sheet.
Thankyou lots BONGOandOUT. :roll:
Post by mikeonb4c » Fri Feb 15, 2008 6:09 pm
Cripes. From memory it should be be the rather obvious looking knurled cap in a line more or less up from the dipstick i.e. towards the front end of the rocker cover. I'm guessing, but it should have a dripping oil can symbol or similar on it. Its certainly under the same engine cover as the dipstick anyway. If in doubt, wait for further replies to your post.
Good luck 8)
Post by francophile1947 » Fri Feb 15, 2008 6:12 pm
mikeonb4c wrote:Cripes. From memory it should be be the rather obvious looking knurled cap in a line more or less up from the dipstick i.e. towards the front end of the rocker cover. I'm guessing, but it should have a dripping oil can symbol or similar on it. Its certainly under the same engine cover as the dipstick anyway. If in doubt, wait for further replies to your post.
Good luck 8)
Isn't that for your diesel engine Mike?
Sorry but I've never even seen the petrol engined version :oops:
flippa
Post by flippa » Fri Feb 15, 2008 6:20 pm
on my v6... dipstick is passenger side...oil filler cap is under drivers seat....i can see the confusion as momentarily you may think this has summat to do with the atf dipstick which is nearby the oil filler cap...well it had me for a mo anyhow :lol: :lol: :lol:
apole
Post by apole » Fri Feb 15, 2008 6:33 pm
As said before it's under the drivers seat, black plastic cap on top of the engine. Just behind that is the dipstick for the autobox and nearer the outside is the power steering reservior.
Andy
Post by mikeonb4c » Fri Feb 15, 2008 6:45 pm
Good luck 8)
Oh crap :oops: I really should learn to read things properly. An excess of enthusiasm I fear.
I'll fetch me other coat (I fetched the first one last night).
Peg leg Pete
Post by Peg leg Pete » Fri Feb 15, 2008 6:57 pm
Slow down Mike, life is not a race :roll: :wink:
Image Pete
Ozric
Post by Ozric » Fri Feb 15, 2008 9:43 pm
I've been waiting for this moment... http://uk.youtube.com/watch?v=Ph7mw8KquJ8 as long as it's in the same place.
cheffy34
Post by cheffy34 » Sat Feb 16, 2008 12:48 am
flippa wrote:on my v6... dipstick is passenger side...oil filler cap is under drivers seat....i can see the confusion as momentarily you may think this has summat to do with the atf dipstick which is nearby the oil filler cap...well it had me for a mo anyhow :lol: :lol: :lol:
I concur pain in the ass when you first change the oil, you have to keep walkin around the van to check the level :roll:
chuckgaish
You Tube Bongo
Post by chuckgaish » Sat Feb 16, 2008 9:47 am
Ozric, Well done for the link, I have just started to do jobs on my daughter in laws Bongo or as I am told its my Grandson's, anyway managed to do all the brake pads and then renew the earth on the fuel tank sender, but where the **ll was the engine guessed it was under the seat but no way could I get in to it, and then sinple change a bulb er no not simple, BUT THAT video on you tube has done the job.
Thanks to the maker of the clips. Keep them coming. :lol:
