Engine Temp
Raff
Engine Temp
I know this has been asked before but before fitting a Mason Alarm what is the normal average running temperature of the engine. ie 90 / 100
- dandywarhol
- The Great Pretender
- B*Witched Blingo
Glad you asked....
Does that mean when you have the alarm fitted it changes the temp gauge to read 1 oclock then instead of 11
You Tube Films Click Here
Ralph
- haydn callow
I have a TM2 temp/alarm fitted. The sensor is fitted under one of the bolts that hold the rocker cover on to the inlet side (drivers) of the cylinder head. There is quite a differance there and the same position on the exaust side.
My gauge normally reads between 88 & 94 depending on speed/load. What it reads and where it reads is not really relevant as long as you know what it normally reads wherever you are taking it from. I have set it to alarm at 100 should the temp go above normal.
If I was taking the reading from the exaust side I suspect it would read around 10 higher.
- Peg leg Pete
- haydn callow
- Peg leg Pete
- dandywarhol
- Peg leg Pete
- brorabongo
I could be wrong, but I though I was measuring the head.
It did fall out on me twice before, (mines not siliconed yet, like Missfixit's) whilst driving.
First time, which give a lower temperature when hanging in the air above the manifold cover.
Second time, it landed on the manifold cover, which was too hot for the thermometer to measure, which made my heart beat a bit faster, and my a**e nearly gave way!!!
In general, I also found the readings handy to decide how long after the glowplug lights gone out, before turning the key. So if the engine temp is very low leave it for longer before starting up, and if the engine is still warm, I turn key as soon as the lights extinguish. Which I think is especially usefull, when using veggie oil.
I can easily try it in the other side though, or tape it to a hose? I which case, which hose could I measure?
Pete
