Quick question re suspension
WISHIHADABONGO
Post by WISHIHADABONGO » Thu Feb 14, 2008 6:25 pm
Rear of the bongo seems a bit well knocky,like over bumps etc, is it bushes or dampers
from experience what is the likely cause?
Si :roll:
Post by bigdaddycain » Thu Feb 14, 2008 6:29 pm
Rear droplinks most probably...
WISHIHADABONGO
Post by WISHIHADABONGO » Thu Feb 14, 2008 6:30 pm
bigdaddycain wrote:Rear droplinks most probably...
cheeRS, shall I do the anti roll bar bushes at the same time?
:D
Peg leg Pete
Post by Peg leg Pete » Thu Feb 14, 2008 6:49 pm
I would, just had ours done, much better ride and lot less knocking :wink:
Image Pete
Post by bigdaddycain » Thu Feb 14, 2008 7:10 pm
Have a check on the anti roll bar brackets too,fit the bushes with the axle on axle stands, (not on the jack) as they need to be torqued up in the resting position.... :wink:
