My mechanic has just told me he's tried several compression tests on our P reg bongo, 59,000 miles from Elite Campers, and it's failed every time. The glow plugs have recently been changed and we've had a new alternator fitted. He's saying there's a possibility it's the piston rings but in all likliehood we'll need a new engine. Can this really be true? Has anyone ever heard of this and if so is there anything else it can be? Basically it's not got enough compression to start, we have to use a squirt of easystart up the inlet to get it going.
Any advice gratefully received, Josh, London.
COMPRESSION TEST FAILURE
joshwhitehead
Welcome to the madhouse - not a good start!
I would have thought a new engine is pretty drastic. You can test for worn pistons rings by putting a squirt of oil in each cylinder - this will raise the compression briefly. Another possibility is burnt exhaust valves. Replacing/reseating the valves is a lot easier, but still requires the cylinder head to come off.
How long have you had the Bongo? It may just be that it's stood for a long time and the piston rings are sticking in their grooves. You can get stuff (can't remember what it's called) to free the rings - might be worth trying as a cheap opening idea.
Good luck.
Good luck.
- The Great Pretender
Remember reading somewhere that coke works dont know if it is true though.francophile1947 wrote:Welcome to the madhouse - not a good start!
Good luck.
- dandywarhol
In the engine GP, or up yer nose??The Great Pretender wrote:Remember reading somewhere that coke works dont know if it is true though.francophile1947 wrote:Welcome to the madhouse - not a good start!
Good luck.
Any figures for the compression test ?
