Coolant top up?
manners
Coolant top up?
Post by manners » Fri Feb 08, 2008 5:30 pm
I last checked my coolant about two months ago when i toped it up( it was about half an inch low in the expansion tank) Ive done about 500 miles since checked it today and its on min is this normal loss through evaporation or do you think i have a small leak ?
waycar8
Post by waycar8 » Fri Feb 08, 2008 5:55 pm
definatley a leak, check all your hoses
Post by Doone » Sat Feb 09, 2008 2:01 pm
If you can't see any obvious leaks, look for water/rusty stains as sometimes the coolant will hit a hot engine part and evaporate, so you don't notice a water drip, or a pool under the van.
