lochan2
Post
by lochan2 » Mon Feb 04, 2008 6:15 pm
Reference my earlier posts with regards to ABS light permanently on, have just had the sensors checked by my local garage and he reckons that they are showing reading that are 'acceptable' and therefore cannot find any reason for the light to show. My 1995 Bongo does not have the diagnostic port as apparently fitted to later Bongo's. So does anyone have any ideas please, hopefully before the MOT is due.
Nibs
Post
by Nibs » Mon Feb 04, 2008 9:21 pm
robdrinky
Post
by robdrinky » Mon Feb 04, 2008 10:25 pm
have you unplugged the modulator/pump unit.also there may be a abs control unit behind your glove box you could also unplug.
best of luck
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
lochan2
Post
by lochan2 » Tue Feb 05, 2008 5:54 pm
Thanks guys, next question
how do I remove the dial binnacle to get to the ABS Light. PLEASE don't say theres some screw to undo as I have one of those walnut veneer dash fascia fitted (as imported) and I think its glued to the original dash
cheers Lochan2
scanner
Post
by scanner » Tue Feb 05, 2008 7:29 pm
All right I won't tell you there is "some" screw to undo, there are 4 - I think.
Two under the lip at the top and one either side of the steering column, no doubt somebody will tell you if I'm wrong.
I'm trying to remember from when I fitted my coolant alarm.
lochan2
Post
by lochan2 » Tue Feb 05, 2008 7:40 pm
Cheers Scanner, guess some gentle prising is going to be needed
Nibs
Post
by Nibs » Wed Feb 06, 2008 12:00 am
Yep 4 screws the prise gently, 2 multi plug connectors then the binacle comes off. Check printed circuit board clean it, pull out the small bulbs as well then make sure when you put them back that good contact is made. Hopefully this will solve your problem. Good Luck
Cheers Nibs
