Banjo filter removed (to be replaced later)..with no obvoious difference in performance.
Engine runs fine if revved but cuts out at low revs.
Then we noticed that when the engine stalled or when on tickover (which it would do for about 30 seconds) that there was a fuel drip coming from the pump.
Drip stopped after about 1 min if engine swithed off or immediately when engine was revved above 900rpm.
I've tried the search facility but not come up with any real suggestions.
1. Does anyone know where I can source a new pump if needed.
2. Does anyone know where I can get new seals if this is all that is required.
My usual sources like AVA and bongobits don't list them.
As I do a very high mileage and normally run on 50% rapeseed oil, it has been suggested that the veggie oil may have affected the seals..what do you think?
All help & suggestions appreciated.
H
