Oil staining
Posted: Wed Jan 30, 2008 4:15 pm
by Glynanderson
I've noticed some oil staining around a flange joint that wasn't there when I bought my Bongo two years ago.
It's under the driver seat toeards the fronttowards the front, a big squareish pipe joining a round one that disappears towards the front of the engine.
I tried tightening the bolts but they seem quite tight.
Any ideas.
Will load pictures later if needed.
Posted: Wed Jan 30, 2008 7:23 pm
by haydn callow
I think you will find this is quite common.
It comes from a silacone seal and the mess is from the EGR. Not a problem and as long as you are not useing oil I don't think you need to worry
Posted: Wed Jan 30, 2008 7:38 pm
by missfixit70
Agree with Haydn, sounds like the egr return pipe into the air inlet manifold, if it bothers you it can be blanked off or removed. I did soon after getting mine, didn't like the idea of that muck going into the air inlet, among other factors.
Posted: Thu Jan 31, 2008 9:56 am
by Glynanderson
HI,
Thanks for that info.
May go down the EGR blanking route.
Would this staining also explain the black smoke when accelerating which didn't used to happen?
Guess my Bongo's getting old :0(
Posted: Thu Jan 31, 2008 11:20 am
by bigdaddycain
If the EGR system isn't working properly (a common fault) excess smoke can be visible glynn. Blanking, or removing the EGR will help, if thats the source of the black smoke.
Posted: Thu Jan 31, 2008 1:23 pm
by missfixit70
Yep it definitley sounds like it's time for the egr to be binned if you've got black puffs as well Glyn :wink:
Posted: Thu Jan 31, 2008 2:13 pm
by Glynanderson
OK, looks like it's blanking time. Does anyone know if any kits are available, saw some on flea bay a while ago.
Posted: Thu Jan 31, 2008 2:25 pm
I THINK (but memory is vague) that Allans of Plymouth (BF member Doone) do a kit. Try them. Someone else does too but at that point the memory fails me :roll:
by maxheadroom
Hi Glyn,
The guy who sells/sold the kits on e-bay is or was a member on here I think.
Posted: Thu Jan 31, 2008 8:03 pm
by missfixit70
I got my kit from nick skidmore who is a member on here, his kit allows the whole lot to be removed (as well as a liberal amounts of knuckle skin :roll: , but worth it IMO), Allans kit is two blanking plates which can be fitted leaving all the pipework in situ, much easier & just as effective, if not as satisfying as getting rid of the useless pipework etc. Not sure if Nick is making any more kits up, but try pming him.
Posted: Thu Jan 31, 2008 8:16 pm
by brorabongo
I've still not fitted my Nick skidmore kit. :oops:
I don't have the right size spanner yet. (thats my excuse, and I'm sticking with it!) :lol:
Posted: Thu Jan 31, 2008 11:36 pm
by missfixit70
That's no excuse Brora :lol:, I'd imagine the outside temperature & weather is agood enough excuse for you though :wink: I reckon big stilsons should get in there ok, you aren't going to need the coupling nut again after all. I lent my 36mm spanner to my friend who has now b***ered off to spain with it :evil:
Posted: Thu Jan 31, 2008 11:46 pm
by kawasaki kid
Your friend must have had big nuts. :shock: :oops:
Posted: Fri Feb 01, 2008 3:25 am
by MountainGoat
I pm'd Nick Skidmore during the first week in December asking him if I could buy one of his EGR blanking kits from him. I have yet to recieve a reply. :(
Posted: Sat Feb 02, 2008 1:59 am
by The Great Pretender
[quote="missfixit70"] black puffs ?...any flashing blue lights outside your house? 8) 8) 8)
