Oil staining
Oil staining
I've noticed some oil staining around a flange joint that wasn't there when I bought my Bongo two years ago.
It's under the driver seat toeards the fronttowards the front, a big squareish pipe joining a round one that disappears towards the front of the engine.
I tried tightening the bolts but they seem quite tight.
Any ideas.
Will load pictures later if needed.
Any ideas.
- haydn callow
I think you will find this is quite common.
It comes from a silacone seal and the mess is from the EGR. Not a problem and as long as you are not useing oil I don't think you need to worry
Agree with Haydn, sounds like the egr return pipe into the air inlet manifold, if it bothers you it can be blanked off or removed. I did soon after getting mine, didn't like the idea of that muck going into the air inlet, among other factors.
- maxheadroom
I got my kit from nick skidmore who is a member on here, his kit allows the whole lot to be removed (as well as a liberal amounts of knuckle skin
, but worth it IMO), Allans kit is two blanking plates which can be fitted leaving all the pipework in situ, much easier & just as effective, if not as satisfying as getting rid of the useless pipework etc. Not sure if Nick is making any more kits up, but try pming him.
- brorabongo
That's no excuse Brora
, I'd imagine the outside temperature & weather is agood enough excuse for you though
I reckon big stilsons should get in there ok, you aren't going to need the coupling nut again after all. I lent my 36mm spanner to my friend who has now b***ered off to spain with it
- Tribal Elder
- The Great Pretender
