V6 Misfire
caleybongo
V6 Misfire
HI Folks,my V6 has developed a misfire/problem,it is now effecting the auto box change,I have tried the wd40 route,has anybody any ideas or similar problems?
Re: V6 Misfire
I had simaler prob after hitting standing water, it did dry out check your plugs , dizzy cap, maybe one of your ht leads has gone down, sorry but process of elimination, sometimes if your down on a cylinder it will dump fuel down the exhaust and drown the lamda sensor, again it will dry out, failing that back to plan 1caleybongo wrote:HI Folks,my V6 has developed a misfire/problem,it is now effecting the auto box change,I have tried the wd40 route,has anybody any ideas or similar problems?
kawasaki kid
- Tribal Elder
firstly buy a neon spark plug tester and check all six plugs.rules out leads,cap,rotor arm.(they cost a quid or two)make sure you rev up and observe the flashing...
if nothing then found remove all the spark plugs and inspect for fouling on a particular plug.or replace (ngk plugs are best for jap engines)..
disconnect the ignition then do a compression test(if you have a compression gauge,availble on ebay or machine mart) one by one all should be about equal at least 120psi.
If its a ignition fault you should find it no probs
beccapeter
I imagine you've checked your plugs, but in case you haven't we've had a problem with the oil seal on the rocker housing covers, which have allowed small amount of oil to seep into the spark plug chamber. This automatically causes quite a juddery misfire.
It's a quick job for a garage that knows what it's doing, but the parts are pricy, so I hope for your sake it isn't that.
Peter
Peter
