Tyre Pressures?
Stubbsy
Tyre Pressures?
Post by Stubbsy » Tue Jan 29, 2008 8:16 pm
Hi All,
I have just bought a 2WD AFT Bongo which has the ever popular RX8 wheels fitted..... The tyre size is 225/45/18 All round.
Could someone please advise me as to what tyre pressures I should be running for daily road use? 99% of the time there are just 2 people in the vehicle and no kit and then the occassional "fully loaded" trip away.
Thanks for the advice!!!!
Stubbsy :D
robdrinky
tyre pressure
Post by robdrinky » Tue Jan 29, 2008 8:23 pm
usually there is a decal inside the fuel flap or door frame giving recommended pressures.
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Post by Bob » Tue Jan 29, 2008 8:52 pm
Welcome aboard Stubbsy, hand book says 1.8 bar, front and 2.4 bar, rear for standard tyres. I know a lot of folk on here successfully run higher pressures.
Might be worth trying a search for 'Tyre AND Pressures'.
Post by francophile1947 » Tue Jan 29, 2008 9:38 pm
It's a case of suck it and see when you don't have standard tyres - try 35psi all round and see how it handles and the tyres wear.
madmile
Post by madmile » Tue Jan 29, 2008 10:57 pm
I know its a heavier vehicle, but plenty of people on the VW forum seem to be running T4's with 18's at 45 psi :shock:
bongo rbk
Post by bongo rbk » Wed Jan 30, 2008 12:22 am
I run on rx8's with 235/40/18's on and the tyre suppliers said 42 psi.
They seem to be fine and i trust the guy i've used him for years.
cheffy34
Post by cheffy34 » Wed Jan 30, 2008 12:28 am
40 psi 225/45/18s
Post by bigdaddycain » Wed Jan 30, 2008 5:05 pm
I run my 225/45/18's on 40 p.s.i. Stubbsy. (though i may up it to 42p.s.i)
The handbook figures for tyre pressures are for the tyres the bongo left the factory with.
Stubbsy
Post by Stubbsy » Wed Jan 30, 2008 7:17 pm
Excellent - thanks for the warm welcome and helpful info guys and girls.
Will set them to 40psi and go from there.
Much appreciated.
Stubbsy :D
