'Drive' or 'Neutral' at traffic lights?
Colin Lambert
The argument rages on about whether one should put the gear selector in neutral when waiting for shortish times such as traffic lights. I have always been a 'put it in neutral man'.
I have just spoken to a chum with a Scooby auto estate and apparently Scoobies put themselves into neutral after a short stationary wait such as traffic lights and then re-engage D when you hit the accelerator.
So that answers the question, at least as far as Subaru are concerned and confirms what I have always thought/done.
trevd01
Thats intersting Colin.
I had never heard of this feature . Do Subarus still have 'Hill Holder' footbrakes? That would work well if the box actually puts itself into neutral. I assume you are talking about the Prodrive Sportshift box, which AFAIK is a full auto, not a robotised manual?
Certainly modern autos (which clearly excuses the basic Bongo autobox) hardly creep at lights (but they don't roll back either). Although in fact I first had a 'no creep' autobox on a Vectra in about 1995 or thereabouts. So the Mercs , Audis and Landies I have had in recent years cleverly transmit little or no drive with your foot off the accelerator at the lights. Those sort of feel like they are in neutral, but are not.
I drive an auto because it is automatic, though - I let it get on with its job and leave it in D.
Mr Halibut
trevd01
I have posted the ROSPA advice ("When stationary in traffic, even for many minutes, it is not necessary to move the gear lever into neutral") before.
http://www.rospa.com/roadsafety/advice/ ... rboxes.htm
Here is another source that gives the same advice.
http://www.autoboxes.co.uk/drivingautos.html
Leave it in D and imagine you're a cyclist - don't stop at red lightsbigdaddycain wrote:I'm inclined to agree trev, i used to knock it into neutral everytime...but i had a few panic moments,where i'd apply throttle as the lights turn green,but nothing would happen, as i'd left it in neutral!![]()
I pretty much leave it in drive now...
Majorbloodnock
Majorbloodnock
I tend to swing either way, but that's another story...bigdaddycain wrote:I'm inclined to agree trev, i used to knock it into neutral everytime...but i had a few panic moments,where i'd apply throttle as the lights turn green,but nothing would happen, as i'd left it in neutral!![]()
It can be worrying if you have also forgotten to re-select D and you roll back a little after sitting with your foot on the brake!
I have never accidentally released the brake when leaving the auto in drive at lights... It just seems to be the best way to go in my opinion.
If you are at the front of the queue especially.... If those lights suddenly turn to green,and you arent prepared for it, a bit of a mad scramble for drive coud ensue...you could just as easily put it in reverse if you move the lever quickly enough in a rush...
John the sparky
trevd01
The old ones are the best, eh?
I love the way we can debate the same old subjects, over and over. Just takes a new slant like Colin's observation about Subarus, and we're off.
That's one of the things that makes the forum so addictive.
(Discovered today, by the way, if you are writing in brackets you can't put February 08)
is the code for the 'cool' smiley
Code: Select all
(Discovered today, by the way, if you are writing in brackets you can't put February 08)Code: Select all
8) is the code for the 'cool' smiley-
coco bongo
I thought that only applied to a manual car, where the clutch could burn out,if you were holding the car on an incline,riding the clutch.coco bongo wrote:Im a neutral man, I go by the driving instructors procedure "If a pause turns into a wait, put in neutral".
