Steering went stiff on roundabout
Hi everyone.
My wife reported that the power steering seemed to fail on a roundabout yesterday and then came back on a second later.
I have found an earlier thread but it is now locked and there was no solution found.
Tonight Im gunna check the fluid and see if any of the belts are glazed.
Any other things I should check out.
cheers
boyzie
cheers
boyzie
Most likely cause, I would have thought, would be low fluid level in the power steering. I had it happen on a bus once, and this was the cause then. Only happened when I put more than a certain amount of lock on. Overtaking, sweeping bends, wide corners, it drove perfectly, but when I had to turn a sharp corner it suddenly went very stiff as there was no longer any power assistance. Straightened up and all was fine again until the next corner.
this happend to me a week or so ago.
As I pulled off the main road into a slip road to turn left the streeing went stiff, appeared OK as I made the turn but for some distance I kept getting a stiffness feel. Got home OK just round the corner.
I contacted the person that posted the original locked theard to see what had happened to him in the end. He said his trouble went on for a few weeks but dissappeared the day before it was due in to the garage?
Mine has not done it since.
Mind you i'm just waiting to hear if it passed the MOT today.
Regards Grahame
Regards Grahame
Joanie2 has had a sex change and is remaned Bert
Mine did the same a couple of months ago as I was going to full lock & back quite quickly, lost assistance for a second or two, no engine problems & fluid level fine, happened twice in a matter of a week or so, then not happened again. Had forgotten about it until I saw this thread.
- dandywarhol
Interesting thread. Mine used to go "heavy" when accelerating on a cold engine which I put down to the fluid being cold and viscous.
I changed the fluid last week and it's much better now - the old fluid was a bit dirty and streaky.
- brorabongo
- helen&tony
stiff steering
Gosh...reading this has got me scared....my left elbow is knackered, and I can't lift a 3 litre bottle of cola without severe pain....I don't know if I could handle a car if the steering suddenly went very hard. Is there any preventive maintenance that could forsee such a problem? Whilst on this note, is there a good schedule of maintenance for complete problem prevention , other than the service schedule....namely normally occuring problems (other than the cooling, as we've got that taped)
- dandywarhol
Pretty easy but could be messy!brorabongo wrote:Is that an easy job to do, dandy?dandywarhol wrote: I changed the fluid last week and it's much better now - the old fluid was a bit dirty and streaky.
Have a 5 litre size container/measuring can handy.
Remove the return pipe from what looks liks a spout in the pic
Put the pipe into the container - some fluid will spill out.
Have 2 litres of fresh ATF/power steering fluid to hand and start the engine.
The fluid will gush from the return pipe at an alarming rate and needs to be replenished as it empties - it'll empty the system in seconds!
Turn the engine off when the fluid looks clean.
Reconnect the return pipe. Top up the resevoir to the full mark.
Start the engine and turn the steering from lock to lock 3 or 4 times to bleed any air out.
Recheck the level and Bob's your great Auntie
The whole thing can be done in 15 minutes and allow for 2.5/3 litres of new fluid
