Solenoid repair kits
The starter solenoid repair kits from Southampton Auto Electrical come with a new plunger but only one contact. However on the last 2 I have stipped it's always the contact that is not supplied that needs replacing....!!!
Dave at Southampton Auto Electrical is looking into sourcing the the second contact, otherwise its "fabricate your own!".
Their number is 02380 211988 not the number in a previous posting that goes to the fax machine!
Watch this space for further details re 2nd contact
If you need a temporary repair (ie get me home..!) you can space the contact in by using a standard size washer, the plunger then touches on fresh copper.
BEWARE. Make sure the plunger does not foul on the copper bolt heads if the washer is too thick and ensure the washer is placed between the contact and the insulator. At your own risk..!! This is a temporary measure.
I think i am gonna have to give dave a ring as mine only came with the small bit as you say but it was the larger piece that was totally pitted think i still have both old bits so can send them to him if he likes just so he can see both
suprised know one mentioned this when it was up on the forum last time well done tur8o for bringing this up
Dave called me this morning to say as it turns out there other contact is available....and he can now supply it , just as my new starter turned up in the post, damm!!
Oh well hopefully other can benifit from this now and if anyone needs a brand new starter or an old one with brand new solenoid contacts and plunger then I have one...
- brorabongo
Prepare to be bombarded with Pm'snobber wrote:Dave called me this morning to say as it turns out there other contact is available....and he can now supply it , just as my new starter turned up in the post, damm!!
I would be tempted, if it was not for lack of funds just now
Yes spoke to him this morning, he'll confirm it is the correct part when he receives them, early next week.Dave called me this morning to say as it turns out there other contact is available
The plunger and Both contacts (if correct) should cost under £20
The extra contact for those who already have plunger and a single contact for a few pounds.
Update to follow
Update on solenoid kits
Can confirm that Auto Electrical Supplies have sourced suitable contacts for the whole solenoid system - I ordered last week and got the solenoid plunger as well as 2 sets of contacts for £18.80 - no carriage charge.
I just mentioned Mazda Bongo and they new what I wanted. Telephone number is 02380 211988 and not the previous Fax number quoted.
