There seems to be a very small patch of exposed metal, at the top of each pin.
My meters fubar, so can not try it out to see if so.
Not if you have fault with a floating current or induced from a high capacitance cable.stringman wrote:You can test them in situ with a volt meter. If you have 12 volts both sides the fuse is ok
brorabongo wrote:and have found that you can test the mini blade fuse, whilst still in situ by testing for continuity across the two very small patchs of metal
I have tried to answer twice.I'm I right in saying that the fuses can be tested in situ, with a continuity meter?
