How do I stop the Sliding door Freezing to the Body
B*Witched Blingo
Post by B*Witched Blingo » Tue Jan 22, 2008 11:40 pm
Can anyone help..
Big rain lots of it and then deep frost.. equals morning rush and no access to bongo 1st with a key and then when managed with key, door well and truly stuck. I don't want to damage the seal by just pulling..
Has anyone any suggestions please. I was thinking of vasolene on the seal.
You Tube Films Click Here
Post by missfixit70 » Tue Jan 22, 2008 11:43 pm
hairdryer if it's frozen? sure the door hasn't jammed? Remember seeing a few posts about this happening to people, needs a bit of jiggery pokery inside the door mechanism if so, hopefully not though :wink:
B*Witched Blingo
Post by B*Witched Blingo » Tue Jan 22, 2008 11:50 pm
I had a similar problem with a Toyota Lucida years ago, but I was able to poor tepid water over the length of the door.. I couldn't this morning as we have a rail over the top..
I was doing the usual morning rush, check tires are up. Nobody or anything underneath etc etc, but could I get the door to defrost not a blummin chance. Trouble was when I came home the door must have defrosted and come slightly ajar as interior rear light was blaring away.. Oh know I thought.. One flat battery coming up or 2 in our case. Thankfully she stared straight away.. Phew.
Good idea about the hair drying. I will leave the old one out handy ready to do the deed..
Cheers Miss fixit..
roosteruk
Post by roosteruk » Tue Jan 22, 2008 11:50 pm
Boiling water on the gaps, DON'T go on the glass.
A smear of Petroleum Jelly can help, I don't have any, will have to ask someone for a smear.... :lol:
Problem with hair dryer, outside, 240V, in a rush, trip over wires, etc.
If you have time, you can try that method, but boiling water always works for me on my work van.
Karl
B*Witched Blingo
Post by B*Witched Blingo » Tue Jan 22, 2008 11:53 pm
Seriously do you think Petroleum Jelly, Vaso will work.. I don't honestly know why I that even entered my head.. Or
R you just winding me up lol...
madmile
Post by madmile » Wed Jan 23, 2008 12:00 am
Any waxy , greasy film on the rubber should stop the water sticking. If its a problem then I would be tempted to get some silicone spray and spray the rubber and the point where it seals to the door.
Be a little careful with boiling water as I had a very bad mark on the lacquer of a van when I tried to remove a sticker and it took a couple of hours careful polishing to get it out.
B*Witched Blingo
Post by B*Witched Blingo » Wed Jan 23, 2008 12:06 am
Thank you for your help.. I will test the vaso theory out tomorrow and wait for the next frost..
Any other suggestions most welcome.. I don't want to wreck the seal or windows...
Post by Bob » Wed Jan 23, 2008 2:06 am
definitely go with trying to stop the 2 bits freezing together rather than trying to seperate them when frozen. I have sprayed de-icer on the closing parts with good effect in the past, before closing.
crazy uncle gray g
Post by crazy uncle gray g » Wed Jan 23, 2008 9:08 am
:roll: Bless it`s little cotton socks, buy it a home :arrow:
http://www.shedtopia.com :lol: :wink:
cheers! party on dudes.
karena
Post by karena » Wed Jan 23, 2008 10:56 am
not allowed bongo for work cos someone wants to play in it, but had same problem with my car yesterday,
tried hot water, de icer spray and in desperation finger nails (not recommended for bongo or people with expensive nails) Finally got into the car set off down the icy road and the passenger door flew open obviousely it had de frosted after i,d been writhing at it.
In my case not a problem no passenger empty road and much reduced speed due to the ice,but it could have been a dire situation for some-one on a school run for example.
Baldeagle
ice!
Post by Baldeagle » Wed Jan 23, 2008 11:01 am
Seem to remember many years ago, someone recommending glycerine,I obtained a bottle which I have had for years and when winter is approaching just smear it on a rag around the door rubbers.However dont know if it would be available easily now as I guess it could be used for more sinister applications!! :wink:
Hooligan
Post by Hooligan » Wed Jan 23, 2008 11:19 am
At the airport I work at we use pigs urine to stop the aircraft controls freezing... but I'm not sure that's an appropriate solution for my Bongo!! :lol:
crazy uncle gray g
Post by crazy uncle gray g » Wed Jan 23, 2008 1:32 pm
:shock: Hooligan, your not telling PORKIES are you ? :P
Hooligan
Post by Hooligan » Wed Jan 23, 2008 2:02 pm
Nope. Honest truth, It stinks and its messy...but it works. Wonder who came up with that idea??
brorabongo
Post by brorabongo » Wed Jan 23, 2008 9:25 pm
crazy uncle gray g wrote::shock: Hooligan, your not telling PORKIES are you ? :P
Aye, I think Hooligans "taking the P***"
How about something like that missfixit? :lol:
ボンゴの激怒 pictures
