got it home, fitted my masons alarm and swapped the clock to a 626 clock.
went out for about an hr drive, to check speedo was working ok, noticed temperature gauge was going to about 9 o clock then dropping back to zero
any 1 any ideas?
no it was leaking at the back of the rocker cover towards the back of the engine.haydn callow wrote:No reason to drop coolant for that job.
Was the oit on the drivers side front of engine behind fuel pump??
If so it is not likley the rocker cover but a silacone seal and they all seem to weep a bit of crud.
