New clutch...no change
dr.p
Post by dr.p » Mon Jan 07, 2008 10:31 pm
Happy New Year to all....need help please.
After a gearbox oil ( manual box) change i am having real trouble selecting 2nd / 3rd / reverse....but only when van is cold, warmed up for a 15min drive and everything is fine. Have been assured that the correct oil and amount were put in - AVA did it so i have no reason to doubt.
Clutch had been playing up anyway, and after much deliberating and posting decided to replace it...but no change, now i'm gutted, broke and short on ideas. Have the van booked in to my local garage on Thursday and could do with some ideas first.
Does anyone know the correct spec of oil and amount.?
Gearbox selects fine when engine is off / on and when clutch depressed and stationary - move and everything goes pear shaped.
thanks.
Post by Ian » Mon Jan 07, 2008 10:49 pm
The oil is type GL4. When you say you had the "clutch" replaced, do you just mean the pedal? Because from time to time, problems have been flagged up with
Pressure plate/clutch cover,
Centre plate/disc; and
Thrust/release bearing
dandywarhol
Post by dandywarhol » Mon Jan 07, 2008 11:12 pm
The manual states Long Life gearoil SAE 75W90. Never heard of 75W90 but I reckon 80 would be fine.
It's filled up to a level plug but I don't know how much it takes.
Never heard of anyone changing the pedal to sort out a dragging clutch Ian :?
dr.p
Post by dr.p » Mon Jan 07, 2008 11:44 pm
clutch was definitely replaced, or a very expensive pedal....thanks for oil spec.
Post by bigdaddycain » Mon Jan 07, 2008 11:56 pm
The gearbox oil level should be fine,you fill it through the filler till it starts to run out,then replace the bolt.
dr.p
Post by dr.p » Tue Jan 08, 2008 12:09 am
ok...so, new clutch, correct gear oil and level and gearbox seems to be fine (or certainly is when warmed up)....any guesses.?
Post by francophile1947 » Tue Jan 08, 2008 12:26 pm
Is it a cable/rod operated clutch or hydraulic?(mine's an auto so I don't know). If cable/rod, try adjusting it cos' you may have too much free play at the pedal. The pedal shouldn't travel much more than about 5mm before you feel the resistance of the clutch springs.
BongoMTBer
Post by BongoMTBer » Tue Jan 08, 2008 2:41 pm
With regard to the forward gears it sounds to me like you gearbox needs reconditioning. How many miles has it done?
Not sure why the reverse should be playing up unless the selector linkcages have been disturbed in which case they may need setting up.
I know of shifting problems in the VAG world which have been sorted using this: http://www.redlineoil.com/products_gear ... tegoryID=7
I would get the box nice and warm, drain and replace and see what that gives you. Got to be worth a punt at around £20, especially as problems started after gearbox oil change.
BongoMTBer
Post by BongoMTBer » Tue Jan 08, 2008 2:52 pm
Cannot find it for that money anywhere anymore. How much does the Bongo g/box take?
Best I can find it is £14/L. Still if it cures the problem it has to be worth it?
Not sure whether to reccomend MT 90 or MTL. Anyone else know?
http://www.opieoils.co.uk/p-1019-redlin ... 0-gl4.aspx
Ralph
Post by Ralph » Tue Jan 08, 2008 3:06 pm
Just been looking at the manual gear box set up in
the members area it looks like it uses cables so
I would expect them to be adjustable it could be
that they need adjusting or the adjusters have come
loose but cant find a clue as to how to adjust them.
dr.p
Post by dr.p » Tue Jan 08, 2008 9:57 pm
thanks for all replies, i like the look of the lubricant :wink: my Father in Law mentioned something about this stuff and worth a punt instead of a gearbox recon....is it better to recon or replace.?
oh, and 83k on the clock.
BongoMTBer
Post by BongoMTBer » Tue Jan 08, 2008 10:59 pm
Recon as it should be loads cheaper. However bear in mind there is recon and recon.
Good luck with the oil.
Which viscosity ae you going with?
