air flow question for a diesel mechanic
Hi all
I am trying to come up with a method of measuring the economy of the bongo while i drive, all my old cars had them and the bongo is missing one.
My question is " is air intake mass flow proportional to diesel use?" or "does turbo compression alter proportions?"
why you ask?
Well most cars have a mass air flow meter and they are cheap as chips on flebay.
could i use one as a economy measure?
ive thought about diesel flow meters, MAF sensing, cant even count injector pulses because the bongo is mechanical. No OBD either.
cheers
why you ask?
cheers
Yes, I agree with the above. The mass flow is proportional to engine speed. The fuel is scheduled according to the power and engine speed selected.
If you could find a way of measuring fuel flow vs. road-speed that would do it.
However, if you had a vintage McCormick tractor, they had a butterfly conrtoled induction and scheduled the fuel according to mass flow...... but you haven't so I'll get my coat.
Theres a better solution - get a wideband Lambda sensor measures oxygen in the exhaust & converts the signal directly to AFR or Air Fuel Ratio. Wideband works over wider range than regular lamda probes
I run one on my drift car, its comes with data logging facilities, used for mapping my engine (thats 540bhp) but easy to plug into anything with a lambda probe hole (£10 welded to exhaust downpipe)
I can highly recomend the VEMS system/unit I have cost is about £180
In fact shortly I will be doing some bongo datalogging to see just how much they are chucking in!
s.w.blackwell wrote:Can you tell me where you got your vems system from? would they sell a sensor on its own?get a wideband Lambda sensor
I plan to fit my own lcd datalogger to the dash and monitor other things, easy to read temps, revs, speed, battery voltage etc just finding it hard to measure fuel use.
ste
Contact rob at vems dot co do uk
