I am having some problems with the rear washer on my Bongo. The wiper is working fine yet the washer is not. The front is all working fine so I am assume it runs off a separate motor. Is this the case and if so is would there be a seprate fuse which I could check first.
Any advice would be greatly appreciated.
Broken Rear Window Washer?
Guys - Cheers for the help. I will check this and let you know how I got on.
