Post
by roosteruk » Sun Dec 30, 2007 1:00 pm
Tog,
As Platty said, I had to manufacture a double din cage. These can be sourced, but at the time, we were in the middle of installation and the only supplier close to us was K&M Acoustics of Wigan, that wouldn't part with one, he kept making excuses, so we walked away.
The small stand-off bracket behind the stereo is only there to support the unit fitted, but it did get in the way of my double din TV/Stereo unit and I had to squash it. This was because I fitted the phono out cables for the roof screen and the plugs were fouling on it. It does not form and part of any vehicle strengthening device, it acts solely as a stereo stabilizer and security bracket. Squashing it doesn't harm the side crush cross member, but you only need to do this in extreme cases.
As David Edwards states, the cage does not fit the whole part of the din aperture. What I did with Marks, was to fit a 6x4 inch piece of 12mm MDF under the cage (on double sided sticky) to the lower plastic shelf part. This held the cage to the top of the aperture and then all the tabs of the cage were bent round in place, job done. Oh, you could just see a small part of the MDF, but if you spray it black before you fit it, it will not be noticeable.
Karl
