Oil Oil everywhere
NickC65
Oil Oil everywhere
Post by NickC65 » Wed Dec 19, 2007 12:00 pm
Just noticed an oil leak - Phoned my mechanic - He had a look and said he thought the oil was coming from the Head Gasket, cleaned it up a bit and then said "No, it actually looks like it's coming from the Manifold!!"
He said he has not seen that before and I thought I would check it out with you guys - He thought there was a chance it had blown in but wanted to poke around before deciding what to do, and said to ask on here
Any comments/suggestions?
Nick
Harry
Post by Harry » Wed Dec 19, 2007 1:09 pm
Is your EGR blanked off.
If not it could be 'crud' from the egr system...usually appears at the front end of the engine on the driver's side.
There is a pipe under there that has a history of leaking/coming loose
good luck
H
http://watcherswildlife.co.uk
Post by mikeonb4c » Wed Dec 19, 2007 2:48 pm
Wasn't there a discussion about something a bit like this recently on BF. Did it involve the intercooler (though can't think how - was it sludge from the inlet manifold backing up or somesuch?). Probably not the same as your problem but I mention it in case. Good luck.
