Thermostat
Bongobus
Thermostat
Post by Bongobus » Fri Dec 07, 2007 5:52 pm
Hi all, im assuming the thermostat is in the metal housing which is to the right of the alternator . Is there any easy way of removal to check the thermostat or does one have to remove half the car as the bolts are underneath facing up.
A pic would be useful to indicate where it is for other members maybe ?
the-bongo-mongo
Post by the-bongo-mongo » Fri Dec 07, 2007 5:54 pm
having done this already, under neath is a plastic cover, 4-6 10mm bolts. remove these. long extension bar up under and two bolts holding housing in place. 14mm i think..easy actually but easier with ramps....
dreamwarrioruk
Post by dreamwarrioruk » Fri Dec 07, 2007 9:12 pm
you can do it from the upright position if you have a good socket set, i checked mine without getting under the bongo
the-bongo-mongo
Post by the-bongo-mongo » Sat Dec 08, 2007 1:59 am
nowt to do with the socket set(mines task master and snap on ) , just better access to bolts and didnt remove anything else to do it.. plus i already had it on the ramps. you can look straight up and remove it. personal choice ! but aint hard either way....
Peg leg Pete
Post by Peg leg Pete » Sat Dec 08, 2007 6:38 pm
You do not have to remove anything else if you work from above, just an exstension on you socket :wink:
Image Pete
DemonAV
Post by DemonAV » Sat Dec 08, 2007 7:58 pm
1) Image
2) Image
3) Image
It's easy. Good luck.
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
Bongobus
Post by Bongobus » Sun Dec 09, 2007 11:18 am
Thanks DemonAV - Those pics are spot on and helpful. :-)
Post by mikeonb4c » Sun Dec 09, 2007 11:25 am
The workshop manual suggests you have to remove a drive shaft on 4WD to remove the thermostat. I believe someone may have managed to do it without removing the drive shaft (I also seem to recall someone saying its not hard to remove anyway) but if yours is a 4WD you might want to be aware. Mine's a 2WD and the thermostat came out OK.
Good luck 8)
DemonAV
Post by DemonAV » Sun Dec 09, 2007 1:29 pm
We did it without removing the drive shaft
Post by mikeonb4c » Sun Dec 09, 2007 6:20 pm
DemonAV wrote:We did it without removing the drive shaft
You are a CLEVER man DemonAV and I'd love to know how you did it. BF member Shad just dropped by to return my workshop manual after borrowing it to do a coolant fill and bleed after replacing a perished radiator hose. He wanted to change the thermostat but said the drive shaft completely blocked access to it.
How did you manage it? :?
DemonAV
Post by DemonAV » Sun Dec 09, 2007 9:54 pm
This is a difficult, but doable. No special tools, only a good set of conventional instruments. Access from top and bottom engine room. Need to delete oil probe for better access (pic2), and release bolts.
Post by mikeonb4c » Mon Dec 10, 2007 12:36 am
Thanks DemonAV - gives encouragement to 4WD owners :lol:
the-bongo-mongo
Post by the-bongo-mongo » Mon Dec 10, 2007 5:10 pm
mine is a 4wd and shaft isnt an issue. if from above , it doesnt even come into it and from underneath, i used a long extension and it was easy that way too. you wont have any bother.
Post by mikeonb4c » Sat Dec 15, 2007 1:48 pm
I find myself wondering who wrote the Bongo workshop manual :roll:
Post by bigdaddycain » Sat Dec 15, 2007 2:57 pm
Sounds a bit like "hayne's manual" syndrome... (strip car completely to gain access to sidelight bulb)
