I know that a previous post has covered fitting new bulbs (available from maplin) to the switches but i was asked when i done mine if LEDs could be used instead.
So today i fitted 12v 3mm Leds (also from maplin)to my switches and they work ok (a ickle bit dimmer but ok in my opinion)
With this in mind any one wanting blue or red switches could be able to put red or blue leds in.
few pics if your interested
led in lamp holder from blind switch (square section cut off)
led soldered into switch blind switch
led before soldering into sonar switch (bent to point forwards)
led soldered into sonar switch (scratched track is pos one)
switches glowing like glowy things
notes: long wires on leds are positive
cheers
ste
