funny noise when idle
gina
Post by gina » Mon Nov 26, 2007 8:26 am
HI I have a funny sort of tinkly noise when idle if I rev it goes away? Water all topped up??? any ideas please
waycar8
Post by waycar8 » Mon Nov 26, 2007 8:38 am
Check all brackets are tight, Andyandden had a similiar problem last year and it was a bracket that the bolt had come loose, i think it was the handbrake cable :? , if you pm them they will tell you :wink:
Post by haydn callow » Mon Nov 26, 2007 10:43 am
Doe's it go away when you turn the steering wheel a bit?? Power steering pump...normal.
Post by mikeonb4c » Mon Nov 26, 2007 1:16 pm
BF member Harry (I think it was) eventually tracked his tinkle down to a spare car key the Japanese owner had hidden in the engine compartment. It had come loose :roll:
