Bica
- Bongonaut
Post
by Bica » Sun Nov 25, 2007 12:58 pm
I did know what the numbers mean but have forgotton. - I have the chance of a 215/80/15 steel wheel with new tyre to replace my skinny.
I have 215/65/15 on the back of my 4WD Freda.
Should I only use this as a' get me home' or whould I be able to leave it on for a period of time
Nao faz mal
Brian
Dave up north
Post
by Dave up north » Sun Nov 25, 2007 1:14 pm
As you 4wd should have differing sizes front to back, I would use it as a get you home.
If you use it with an odd sized partner, you will be breaking the law, I think.
Some people in the past have had transmission problems from using rubber that doesnt fit.
Bica
- Bongonaut
Post
by Bica » Sun Nov 25, 2007 7:18 pm
Thanks for that Dave - Yes I have 215 on the back and 195 on the front.
It was the 80 as opposed to the 65 of the other tyres that concerned me as I assume the skinny would be either 215 or 195 ( I havn't dropped it down to check)
Nao faz mal
Brian
Post
by francophile1947 » Sun Nov 25, 2007 7:24 pm
The 215/80 tyre is 9.8% bigger than the standard 215/65 tyre. This would cause severe problems with your 4WD viscous coupling. I would only use it to get to the nearest tyre dealer at the most. Personally I'd scrap the tyre and replace it with the correct size - it's a lot cheaper than a new viscous coupling.
MountainGoat
Post
by MountainGoat » Sun Nov 25, 2007 7:29 pm
My Bongo came with Alloys fitted with 215/65R15 96H tyres all round. The spare is a standard steel of the same size. Somewhere I read that the steel spare requires different wheel nuts. Can anyone confirm this point.
MountainGoat on Mon Nov 26, 2007 3:37 am, edited 3 times in total.
Bica
- Bongonaut
Post
by Bica » Sun Nov 25, 2007 7:53 pm
Thanks all - I think I will still get the wheel but change the tyre - at least it is the correct width and diameter.
By the way John, do you know if there is likely to be a meet round our way over the new year (whoops gone off my own topic)
Nao faz mal
Brian
Post
by francophile1947 » Sun Nov 25, 2007 8:02 pm
Hi Bica
Tridentlee was talking about a day meet at Southend - I don't know of anything else, but keep your eyes peeled in the Eastern Counties and Fancy Meeting Up sections.
Post
by mikeonb4c » Sun Nov 25, 2007 8:19 pm
I believe the steel wheels do need different nuts MountainGoat (I got nuts with my 4 when I bought them) but no doubt somone on here with more knowledge can confirm that
scanner
Post
by scanner » Sun Nov 25, 2007 8:29 pm
