Interior Lights Delay Dimmer
jackstringer
Post by jackstringer » Sun Nov 18, 2007 6:50 pm
This is a bit Pimp and a bit Techie.
I would like to make the interior lights in Mongo stay on for a few seconds then dim and then off. Like many modern cars have as standard. Now I was wondering if any here have seen a 'smart relay' that I could just connect to the interior lights in the front of my bongo.
I am also tempted to put a 10second delay relay on the strip light near to the sliding door just to give passengers a few seconds to get seatbelts on etc.
I found a electronic diagram of a system that should work but would like to buy a pre assembled one if I can as its less hassle.
Diagram
http://www.csgnetwork.com/dimmerdelayproj.html
Ebay Item for a Ford (180178778480)
http://cgi.ebay.co.uk/Interior-light-de ... dZViewItem
pippin
Post by pippin » Sun Nov 18, 2007 7:40 pm
I doubt the Ford thingy would work in a Bongo.
The cct link brings up a blank page.
roosteruk
Post by roosteruk » Sun Nov 18, 2007 10:45 pm
Try this DIMMER UNIT
I thought of one in the rear, but my rear light is a flourescent.
jackstringer
Post by jackstringer » Sun Nov 18, 2007 11:35 pm
Well for £5 I am going to try the dimmer kit.
The light by the sliding door is a florescent but you can use a 10second delay relay on it just to switch on and off. Which is my plan.
ADAMD
'dome light supervision'
Post by ADAMD » Tue Nov 20, 2007 2:34 pm
Some alarms have this feature, also turns light on as you remotely unlock doors. Refered to as'dome light supervision' on my alarm.
Timer looks like a simple add on though.
